We were running Inventor 2011 / Vault 2011 backed up and upgraded to Inventor 2012 / Vault 2012 the restore worked just fine and data migrated. We had been running for a few months with no issues until we tried to do another restore as a mistake was made and we thought it would be easier just to restore from the previous days backup, we have backups occuring daily. Since the restore inventor keeps on crashing as there seems to be a problem with the project file. The error we are recieving is below, The styles are being pulled from the network but I have tried pointing the paths to both our local working folders as well as the network and I get the same error below. I have also attempted to change the path directly in the registry. Any Ideas?
Incomplete Design Data Folder
The specified folder is not complete with all Design Data and style library files.
Please select a Design Data folder which contains all the necessary files/folders.
Solved by Xun.Zhang. Go to Solution.
Hello @Anonymous,
Please follow below solution to solve it.
Hope it helps!
