Inventor Forum
HELP ON BASICS
2 REPLIES 2
232 Views, 2 Replies
HELP ON BASICS
I am having problems on making rips on my shaft (sorry if anything is wrong, english is not my first language) i need to draw them one by one and extrude the piece? or there is a tool which can help me doing it like design accelerator? Thank you
Tags (1)
2 REPLIES 2
BeKirra
It would be helpful if you attached a sample file, sheet metal IPT in your case.
Please mark "Accept as Solution" and "Like" if my reply resolves the issue and it will help when others need helps.
A circle is the locus of a cursor, starting and ending at the same point on a plane in model space or in layout such that its distance from a given coordinates (X,Y) is always constant.
X² + Y² = C²
Cadmanto
Welcome to the forum.
Like it has been suggested. It would be helpful if you attached the file and an image to show what you are trying to accomplish.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
