That would work however then all users will see all projects. The way I
have it setup now only those projects which a user copies shortcuts into his
local project folder are visible to him.
Not a big deal to recreate the shortcuts but there is no reason why it
should do this...
Sean Dotson, PE
http://www.sdotson.com
Check the Inventor FAQ for most common questions
www.sdotson.com/faq.html
"Tim W" wrote in message
news:2DE14F5007ABFBD1047939C806EC5193@in.WebX.maYIadrTaRb...
> I've gone through several server crashes, and I got fed up with IV
> forgetting where my projects are.
> So, I do this:
> I have a "Project File Shortcuts" folder on the server, while all the
actual
> *.ipj files are in the same respective folder that the part and assembly
> files are (I don't understand why they'd recommend otherwise). Anytime I
> make a new project, I just copy and paste the new shortcut into my
"Project
> File Shortcuts" folder.
> IV is set up to look in this folder for the projects, though all it finds
> are shortcuts.
> When the server goes down, IV obviously can't get to those shortcut
files -
> so it reverts to looking in "My Documents" and the "Default" project
> (atleast with my setup). I guess if you've got some projects stored on
your
> local machine, you could put extra copies of the shortcuts to them in "My
> Documents" - provided that "My Documents" is also on your local machine (I
> guess you'd be out of luck if your IT dept puts "My Documents" on another
> network drive).
> Oh - and I do use relative paths for all my projects and I even use nested
> folders (I don't understand why they'd say this isn't good either?).
> Just some thoughts for ya'll, Tim W.
> "Sean Dotson" wrote in message
> > Our power went out today for a while (wicked storms) and the servers
went
> > down. After I rebooted and tried to start IV I found one of the mapped
> > drives was not up yet. So I didn't have access to my titleblocks,
> > templates, project files etc..
> > So I shut down IV and wait...IT gets the server back up in a few mins
and
> > when I open IV all of my shortcuts to project files (in my local
> directory)
> > are gone.
> > Annoying. It's happened before too so I should know better.
> > Is this an IV thing or a Windows thing. I suspect IV as links to other
> > shortcuts remain. Why does IV feel it necessary to remove these
shortcuts
> > just because it doesn't find them?
> > Sean Dotson, PE
