I am getting the error report as attached when I try to open one assembly, I have no idea what is happenning. The other assemblies I created can be opened correctly. Please help me, I could not do anything about it if I can't even open my Assembly.
Hi Buer622,
I would ask your re-seller to check in with autodesk (you submitted Crash Reports with your e-mail).
So they can lookup the problem submitted on the CE, and they may be able to resolve it.
I hope this helps,
James
In that report you show in your image, write an extensive description of what you are encountering.
I have had success with getting a response.
Also, make sure your SP's and hotfixes are up to date.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
