Inventor Forum
Get rid of button in sketch mode
4 REPLIES 4
itadenm
324 Views, 4 Replies
Is it possible to disable that green "Finish sketch"  and Ok button when your in sketch mode drawing with a Spline?
Kind regards,
Adenm
4 REPLIES 4
JDMather
in reply to: itadenm
Not sure why it is a problem, but I normally right mouse button Create to finish a spline.
itadenm
in reply to: JDMather
Thank you for your answer.
The reason I'm asking this:  I'm doing a sketch upon a image and that button is most time to close to my "anker point"  so it's hard to follow the line of that image.
Kinfd regards
JDMather
Can you attach the file here?
My guess is that you are trying to add too many nodes to your spline (the best spline is only two nodes).
Maybe try creating a simple spline and then add nodes as needed.
itadenm
Hi JDMather,
I attached the file I'm working on  but I don't think I can do this with less nodes.
Kind regards,
