Is it possible to disable that green "Finish sketch" and Ok button when your in sketch mode drawing with a Spline?
Kind regards,
Adenm
Not sure why it is a problem, but I normally right mouse button Create to finish a spline.
Thank you for your answer.
The reason I'm asking this: I'm doing a sketch upon a image and that button is most time to close to my "anker point" so it's hard to follow the line of that image.
Kinfd regards
Can you attach the file here?
My guess is that you are trying to add too many nodes to your spline (the best spline is only two nodes).
Maybe try creating a simple spline and then add nodes as needed.
Hi JDMather,
I attached the file I'm working on but I don't think I can do this with less nodes.
Kind regards,
