That's been the situation yesterday. I think, nothing has changed until now.
Walter
Walter Holzwarth
Solved by Nicolas.Bourquin. Go to Solution.
Dear Walter,
I have reproduced the reported problem.
When german local help for 2015 is downloaded and installed => chinese language is displayed in local help.
I have escalated this problem to our development for investigation.
I hope the problem will be corrected very soon.
Our apologies for this inconvenience
Many thanks.
Best Regards
Please, hit the Accept as Solution button if my post answers your question.
I got a confirmation. The problem should be corrected.
You can now download again the local help for 2015 in german at the same location (link).
For an easy re-installation:
close Inventor >> launch the new exe file downloaded >> answer "yes to all" to the "confirm file replacement" dialog box question
Note: you can also just access to the folder containing the sub-folder "Local Help" for Inventor 2015
(installed by default at C:\Program Files\Autodesk\Inventor 2015\Local Help) and rename it (or remove it) before launching the new exe file.
Many thanks and best regards
