I'm putitng a system together and trying to decide whether to go Quadro or use a Geforce GTX570. The system will be used to put together 3D models that have anywhere from 13-100 parts and we will be running FEA analysis's on these parts. Will a Quadro like the 4000 prove to be much faster for these types of loads? There seems to be no information online showing parformance differences between Geforce and Quadro cards though I see people post in forums that they have switched from using Quadro to Geforce. Any help would be appreciated
dont bother with quadros (unless you're using any other software that needs OpenGL, eg other cad SW).
it's all been explained to death many a time (especially by myself)... search for OpenGL and/or Quadro and should get a load of info. sorry to be blunt, but it's frustrating typing and re-typing the same info over and over.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
I'd go with a 2GB 570 GTX. It has a Win7 rating of 7.9. GTX 560 is less expensive with a rating of 7.8
It's the card family I recommend. Both are also rated for Open/GL 4.1
Ok guys I have a little issue. Just built a new rig, see spec below:
And installed Inventor 2012 on a vanallia install. Iinstalled the OS, Win 7 64bit, updated windows, instaled motherborad and video drviers, then installed inventor 2012, installed sp1 for inventor 2012 64bit
The issue is the toolbar ribbon is missing on the graphics? See below
Any ideas? Thanks
Steve
This looks suspect:
There is something wrong with your drivers / card / installation, unless you really only have some old version of DirectX...
To have a graphics performance like that, I suspect that you have a power supply problem with the above-board power supply to your graphics card. You should have at least one power supply cable going directly to your graphics card.
The graphic card requires two 6 pin power connectors which are plugged in. If only one is pluged in the machine will not boot, so I think the power being supplied to the video card is adequate.
There's definitely something wrong. A soft clay brick and sharp pointed stick will produce a graphics performance index of "1"
i would run a stress test on the graphics card
DarrenP
The next things I am going to try:
Thanks for the suggestions guys. I will keep trying.
Steve
Try a different PCIe slot, you should always start with the #1 slot (closest to the CPU on most boards).
Doh! So after consulting a colleague in the IT department, our system administrator he found that the on-board video for the motherboard was still enabled.
Problem solved. Make sure to turn off your on-board video in the bios or check to make sure you do not have one when installing a dedicated video card.
The video stress tested has passed and now I am trying to sort out why the CPU stress test is failing. Almost there, thanks for the help and suggestions.
