Inventor Forum
Geforce GTX570 vs. Quadro cards
16 REPLIES 16
Message 1 of 17
4244 Views, 16 Replies
I'm putitng a system together and trying to decide whether to go Quadro or use a Geforce GTX570. The system will be used to put together 3D models that have anywhere from 13-100 parts and we will be running FEA analysis's on these parts. Will a Quadro like the 4000 prove to be much faster for these types of loads? There seems to be no information online showing parformance differences between Geforce and Quadro cards though I see people post in forums that they have switched from using Quadro to Geforce. Any help would be appreciated
16 REPLIES 16
Message 2 of 17
sam_m
dont bother with quadros (unless you're using any other software that needs OpenGL, eg other cad SW).
it's all been explained to death many a time (especially by myself)...  search for OpenGL and/or Quadro and should get a load of info.  sorry to be blunt, but it's frustrating typing and re-typing the same info over and over.
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Message 3 of 17
Dennis_Jeffrey
I'd go with a 2GB 570 GTX.  It has a Win7 rating of 7.9.  GTX 560 is less expensive with a rating of 7.8
It's the card family I recommend. Both are also rated for Open/GL 4.1
____________________________________________________________
Dennis Jeffrey, Author and Manufacturing Trainer, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert
Autodesk Silver Manufacturing Partner
Subscribe to the free digital "The Creative Inventor Magazine" now available at: http://teknigroup....
XP64 SP2, GeForce 9800GT-1GB, Driver: 6.14.12.7061, 8GB Ram, AMD Athlon II 3.2 Ghz
Laptop: Win7-64 Pro, 4GB, ATI Graphics on board, 2012 Ultimate, IV2011 or 2010 Pro, all SP's
Message 4 of 17
sbauman67
in reply to: Dennis_Jeffrey
Ok guys I have a little issue. Just built a new rig, see spec below:
And installed Inventor 2012 on a vanallia install. Iinstalled the OS, Win 7 64bit, updated windows, instaled motherborad and video drviers, then installed inventor 2012, installed sp1 for inventor 2012 64bit
The issue is the toolbar ribbon is missing on the graphics? See below
Any ideas? Thanks
Steve
Message 5 of 17
cwhetten
in reply to: sbauman67
This looks suspect:
There is something wrong with your drivers / card / installation, unless you really only have some old version of DirectX...
Message 6 of 17
PACDrafting
try installing the latest driver.
Message 7 of 17
sbauman67
in reply to: cwhetten
No dice, see below. I already have direct X 11 installed.
Message 8 of 17
sbauman67
I have the latest Nvidia driver installed. Smiley Sad
Message 9 of 17
PACDrafting
The 2 screen dumps are showing different DirectX versions?
Message 10 of 17
blair
To have a graphics performance like that, I suspect that you have a power supply problem with the above-board power supply to your graphics card. You should have at least one power supply cable going directly to your graphics card.
Delta Tau Chi ΔΤΧ
Message 11 of 17
sbauman67
in reply to: PACDrafting
Good point, I will look at updating the firmware for the video card.
Message 12 of 17
sbauman67
in reply to: blair
The graphic card requires two 6 pin power connectors which are plugged in. If only one is pluged in the machine will not boot, so I think the power being supplied to the video card is adequate.
Message 13 of 17
blair
There's definitely something wrong. A soft clay brick and sharp pointed stick will produce a graphics performance index of "1"
Delta Tau Chi ΔΤΧ
Message 14 of 17
DarrenP
in reply to: blair
i would run a stress test on the graphics card
DarrenP
Message 15 of 17
sbauman67
in reply to: DarrenP
  • PACD-I think you might be right, the inconsistency may be pointing to the problem. Maybe the firmware on the video board?
  • Darren - Maybe you are on to something, CPU (prime95) and GPU (FurMark) stress tested both failed.
  • Blair-I have checked the power cables to the graphics card and everything looks correct. Two single power cables directly from the power supply are plugged into the graphics card.
The next things I am going to try:
  1. I am going to check the motherboard Bios and make sure the motherboard does not have an on-board video and if so make sure it is not on.
  2. I think the video card firmware may need to be updated due to the inconsistencies of the two different DirectX version reported back. But this is dangerous, I have never had to ever do this and I could end up with a brick.
  3. Pray
Thanks for the suggestions guys. I will keep trying.
Steve
Message 16 of 17
blair
Try a different PCIe slot, you should always start with the #1 slot (closest to the CPU on most boards).
Delta Tau Chi ΔΤΧ
Message 17 of 17
sbauman67
in reply to: blair
Doh! So after consulting a colleague in the IT department, our system administrator he found that the on-board video for the motherboard was still enabled.
Problem solved. Smiley Happy Make sure to turn off your on-board video in the bios or check to make sure you do not have one when installing a dedicated video card.
The video stress tested has passed and now I am trying to sort out why the CPU stress test is failing. Almost there, thanks for the help and suggestions.
