Inventor Forum
GD&T Symbol missing
7 REPLIES 7
Message 1 of 8
dpinson01
4807 Views, 7 Replies
GD&T Symbol missing
I havent found two symbols from ANS Y14.5 2009.
The first one is the continuous feature and the second one is the spot face.
Actually, I defined symbols as a workaround.
Is there an another way to get these symbols. They are not in the Windows GDT fonts as well.
Thank you.
7 REPLIES 7
Message 2 of 8
Cadmanto
in reply to: dpinson01
Can't say as I have seen any of those symbols in Inventor.  As far as the continuous feature you can create somthing similar to this.
CF.JPG by just creating a special hex balloon in the styles.
check.PNGIf this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudoskudos.PNG are appreciated. Thanks!!!! Smiley Very Happy
Best Regards,
Scott McFadden
(Colossians 3:23-25)
Message 3 of 8
dpinson01
in reply to: Cadmanto
That's the solution I use at this time. Maybe in future release all symbols will be available in the hole annotations and feature symbols.
Thank you
Daniel P.
Message 4 of 8
Cadmanto
You can always post an idea in the Inventor IdeaStation and outline what you would like to see.
If you do post a link here to the idea and in the idea back to this thread.
Best Regards,
Scott McFadden
Message 5 of 8
kstate92
Because Inventor 2014 is still using a 20 year-old standard:
Why?  because the current standard only came out five years ago.
Best not to be too hasty about such things. /s
KState92
Inventor Professional 2020
AutoCAD Mechanical 2022.0.1
Windows 10 Pro 64 bit - 1903
Core i7-8700 32 GB Ram
Quadro P2000
Message 6 of 8
dpinson01
I think I'll do that soon. Thank you Daniel P Inventor 2014 sp1 pro WIndows 8.1 64 bits
Message 7 of 8
brettsampson87
After searching for the continuous feature symbol and finding this thread I had nearly given up and then I stumbled across the setting to add it.
1. Click "Edit Layers" button in the "Annotate" tab.
2. Select "Feature Control Frame" from the list on the left.
3. Select "Material Removal Modifier" from the drop down.
4. Way down at the bottom is the option for continuous feature.
To get the symbol to show up the way I have it in the below image I had to place the feature control frame and then create a text box with leader and attach it to the end of the FCF.
I hope this helps someone in the future.
Message 8 of 8
AVIDC2AC
in reply to: kstate92
Someone please give this man an award, and mark this 5 year old response SOLVED!!
Kuddos to you man Smiley Happy
