Inventor Forum
Frost (not frosting)?
2 REPLIES 2
CelticDesignServices
884 Views, 2 Replies
I need to make parts of a model/assembly generate frost build-up.
Thusfar the results I'm getting look more like foam build-up.
Aside from playing with the lighting and such to knock down the "shine" factor, anyone have any suggestions to keep it from looking like a foam bundt cake pan (in this example)?
I'm thinking of maybe taking a HD picture of some actual frost and creating a bitmap/texture to use in place of Inventor's "Course Textured - White".????
Jim
Celtic Design Services, LLC
Inventor/AutoCAD/Vault WorkGroups
Always for hire - celticdesign01ATyahooDOTcom
https://www.facebook.com/pages/Celtic-Design-Services-LLC/184666001666426
Please use the "Accept as Solution" and "Give Kudos" functions as appropriate to further enhance the value of these forums.
Go raibh maith agat (in other words...Thank you!)
2 REPLIES 2
Try creating a new color style. Using a seamless bitmap like one of the attached.
Make the color style semi transparent and tweak the ambient, diffuse, specular and emissive colors to achieve the desired effect.
It usually takes some playing around with them to get what you want.
Mike Patchus - Lancaster SC
Inventor 2025 Beta
Alienware m17, Intel(R) Core(TM) i9-10980HK CPU @ 2.40GHz 3.10 GHz, Win 11, 64gb RAM, NVIDIA GeForce RTX 2080 Super
Did you find this reply helpful ? If so please use the Accept as Solution or Kudos button below. 🙂
Thanks!
Yeah, his is what I was looking at having to do.
I'll see what I can get out of those attachments and post the results here once I get permission to share the final product.
Jim
