My skeleton has lost translation with my frame generator and has offset the sketch. I have tried "Edit with Frame Generator" but the peices seem to stay in place.
You ae more than likely dealing with a corrupted file. Not sure if you have a backup of the assembly and not sure if you can do a replace component on it either as I never tried this. You can try using dethe "task schedular" and run the file tion utility, choose option "Total Rebuild" and "Compact Model History" and let this run on the assembly file and all files for the project. Try opening the assembly then.
Don
Don,
Thanks for the reply, however I am not using any type of vault so these options are not possible. Being that only 2 of us work here we just copy what we need to modify.
Have you tried a "Rebuild All" in Inventor? Sometimes this works....
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
