Please forgive my rookie status here, just learning Inventor 2014. I have gotten the basics and am looking to draw up a mtorcycle frame based on dimensions I have in the shop. I'm just playing around at this point and sketched a trellis frame and used 3/4" ANSI pipe for the tubes. In reality I will be using 1" DOM 0.065" wall tubing.
I notched a couple of the tubes and can isolate/open those individual parts. I have (tried to) follow a couple tutorials on how to "unfold" or rip the notched tube so that I can print out a template, wrap it around the tube and cut/cope it in the shop.
I keep getting an error message saying it can't rip it. Now I drew a tube myself in another part file just by extruding a couple circles and it ripped that just fine, and would unfold it.
Is it the ANSI profile I am using from CC? Is it because it is notched?
To be honest I couldn't follow the steps in the following http://forums.autodesk.com/t5/Inventor-General/Unfold-a-tube/td-p/3168764
I tried to thicken the part, fail haha. I'm not sure what I should be doing here. I can thicken it fine, but then I can't "delete face solid lump"
Again, sorry about the beginner question I'm really starting from the bottom here
Solved by JDMather. Go to Solution.
Check the attached fix.
You Sculpted the surface bodies into a second solid body for the Combine-Subtract.
Inventor sheet metal does not support multi-body solids - thus the error.
I deleted your Sculpt and deleted the extra surface faces you had. (When Copy Object to get the surface - you only need the outer contact surface).
Now I used Sculpt (or Split) to cut away the excess without creating an solid bodies).
I realize this is an old thread, and I've found some newer ones, but this one seems to have the best information. But I'll be damned if I can get it to work on my particular part. The Rip command never seems to work, just errors with "unable to rip". Split does the trick, but thats where I get stopped. I cannot unfold and flattening just makes another round pipe.
I've made a very thin thickened surface as I need to make a paper cut out of this once done, like this video https://www.youtube.com/watch?v=KoOfekvSVsA, but I get stalled after picking the round face as my stationary reference, I have no option to select anything after that.
Part attached.
Hi! This can be done easily. The Thickness value on the part is different than the actual body thickness. Please try the following and Rip should work.
Option 1: Go to Manage -> Styles Editor -> Sheet Metal Rule -> change the thickness to 0.05mm (the body thickness d27).
Option2: Go to Sheet Metal Default -> uncheck "Use Sheet Metal Rule" and change the thickness value to 0.05mm or d27.
Many thanks!
