Hello everyone,
I am facing some troubles when creating documentation from static analysis of my construction. I have put some vertical loads on my model of steel arch support that is used in underground coal mine. Then, after the results of bending moments are displayed, the program automatically attaches these square brackets with values of each peak in the graph. I cannot find a way to switch these brackets off, and the whole thing looks really messy. Is there any way to display graphs only? Thanks in advance for your replies.
Hi Bartosz,
you can't. I suggest to divide your diagram in many diagrams, so you can control their state suppress/unsuppress individually.
Alternatively you can use the Beam Detail command.
Admaiora
