Inventor Forum
Frame - Notch with offset
3 REPLIES 3
tuliobarata
634 Views, 3 Replies
Hey again guys,
Another question using IV 2013  and Frames.
When i get some frames and need to use the feature NOTCH, is there a way to put one offset on it ? like we can do using MITER ?
The solution we've found here is in every member that we use NOTCH, we enter in the frame part and then use the feature THICKEN/OFFSET, this wey i can get the standard offset of 3mm that we use here for welding.
Or, if there is other easy way instead of NOTCH, to make one frame get to other with offset.
The image below shows what i mean, i need to get this off set in the frames on Z AXIS.
Thanks very much!
Túlio Barata
IV 2013
3 REPLIES 3
PaulMunford
in reply to: tuliobarata
Try this:
http://forums.autodesk.com/t5/Autodesk-Inventor/frame-generator-notch/td-p/2193144
Autodesk Industry Marketing Manager UK D&M
Opinions are my own and may not reflect those of my company.
Linkedin Twitter Instagram Facebook Pinterest
tuliobarata
in reply to: PaulMunford
Thanks man!
Well, a good way to solve it with that answer, better than mine when i get many and many frames...
Túlio Barata
IV 2013
PaulMunford
No Problem 🙂
