Greetings,
I'm currently drawing a frame for a gate with the frame generator, it went very smooth untill now.
Afther the basic frame was done I converted the assembly to weldment and added all the preparations/welds.
But now I need to change a couple of dimensions (trough an excel) to compensate changed parts and my fame doesn't adapt anymore.
Only thing that seems to work is deleting the specific section and redoing the welding but it still doesn't addapt aftherwords.
Is this something I did with settings or is this normal? Is there a way arround this so you can have weldments on an adaptive frame?
Kind Regards,
Nico Van Donick
Solved by VDNico. Go to Solution.
I have never converted a Frame to a Weldment, but something tells me that doing so, you would lose the Frame Generator functionality... as you probably suspected by now. This might be a good enhancement request for the Idea Station, the ability to have weldments within the FG environment.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
I'm on 2013 and I'm not seeing this behaviour, although I'm not using an Excel driven frame. I'm using a standard sketch. After making the frame and applying the members, I convert to Weldment (I did pick Normal instead of Inseperable) and applied welds. I exit Weldment, edited the frame sketch to change lengths and returned to the assy file. It updated no problems. I can enter Weldment again and apply more welds. I can change Frame Members to other sizes and they update along with the welds.
Cheers for the replies,
I managed to find my "problem" or solution afther going trough some treads here.
My skeleton sketch ( the part file not the Frame Reference Model) was grounded and even tough it hasn't been a problem in the past, it was now for some reason.
Ungrounding this part made the welded assembly update again.
Just some side info/ideas: (Inventor 2014)
Maybe this occurs when you delete parts of the frame?
Or when you create holes in the frame?
I did both so unclear if these have any effect in the long term.
BOM was also set to normal.
