Inventor Forum
Frame Generator Report
6 REPLIES 6
PACDrafting
362 Views, 6 Replies
Is there any way in standard inventor to find what sketch is related to a frame generator member?
6 REPLIES 6
Yong.Jing
in reply to: PACDrafting
Please  view the skill builder about Frame Generator.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12193815
Yong Jing
Product Support Senior Specialist
Technical Support, CSS, GPS
If my post answers your question, please click the "Accept as Solution" button. This helps everyone find answers more quickly!
如果我的回帖解决了您的问题,请点击 "接受为解决方案" 按钮. 这可以帮助其他人更快的找到解决方案!
PACDrafting
in reply to: Yong.Jing
Thanks for your input.
But I'm afraid thats not what the question is.
Yong.Jing
As you see, all the the frame generator part is published into Content Center, and saved at you idcl file at folder: C:\ProgramData\Autodesk\Inventor 2013\Content Center\Libraries.
After the part is published, there is no way to edit the sketch drawing which has combined with the published part.  You use CC editor to modify the parameters.
Yong Jing
PACDrafting
Not talking about that sketch.
I'm after the sketch within the frame skeleton after the member gets assigned to a line on placement in an assembly.
Yong.Jing
Open the Frame part, in the model browser, you could see the sketch in the browser's dot.
Yong Jing
PACDrafting
Thanks. It's the driven sketch I'm after. As shown in your picture.
Thanks for replying.
