Is there any way in standard inventor to find what sketch is related to a frame generator member?
Solved by Yong.Jing. Go to Solution.
Please view the skill builder about Frame Generator.
http://usa.autodesk.com/adsk/servlet/item?siteID=123112&id=12193815
As you see, all the the frame generator part is published into Content Center, and saved at you idcl file at folder: C:\ProgramData\Autodesk\Inventor 2013\Content Center\Libraries.
After the part is published, there is no way to edit the sketch drawing which has combined with the published part. You use CC editor to modify the parameters.
Open the Frame part, in the model browser, you could see the sketch in the browser's dot.
