I am using Frame Generator and have not been able to miter two members together, though I have successfully mitered another two members of the frame elsewhere in the same Frame Generator assembly. Attached is a screen shot of the error message.. I've tried deleting the existing end treatments before executing the miter and with the check box in the Miter pop-up window. The error message says: "Failed to create the end treatment. The reason for the failure is unknown. Please retry."
I have tried restarting Inventor, my computer, etc. I checked my updates and none remaining are for Inventor.
Help would be much appreciated.
Solved by jalger. Go to Solution.
Hi Bianca,
It looks like you may already have an end treatment on the Frame member.
Try flagging the "Delete exisiting end treatment(s)" option when mitering the corner.
James
Hi Bianca,
Can you do a pack and go on the Frame? Its hard to tell from one screenshot what the issue is.
It looks like you have adaptivity in the frame, it could cause issues. (normally you would only see the issues in the parts your directly mitering).
If its a vault assembly (can't tell from the picture, you may need to take ownership of the files).
If you pack and go the assembly, just pack the parts and the assembly to reduce the zip file size.
James
Hi there,
Here is the folder; I look forward to hearing what you find.
Bianca
Hi Biancascura,
something is wrong with your assy.
I believe that you have open an assembly named something like this Frame0001.iam that was in a project subfolder named "Frame", then you saved it with another name.
That assembly hasn't to be open. It's needed by Inventor to manage all the frame.
A classic Inventor Frame assembly has a part in it that contain the skeletal (it can be a solid...a 2d sketch, a 3d sketch , a mix..etc).
Your assy TubeWeldmentFrameGenerator.iam doesn't have it.
Admaiora
Hi Bianca,
I'm not sure why the issue Exisits (Maybe through some edit).
but I have found that the long Frame members (...0063, 0064, 0065, 0066) all have the same issue, and they do not let you edit or create end treatments. Its strange its like they are Frame memebers but not frame memebers. I blew them away and recreated them and the end treatments work.
I hope this helps,
James
Errata Corrige:
which is your assy? TubeWeldment.iam or TubeWeldmentFrameGenerator.iam ?
Admaiora
Hi Admaiora,
Bianca is using the edges of the Solid model as the frame.
Its not a common practice but it works. (for the long memeber you have to use point to point thats the only catch)
James
Yes, as i mentioned, i know that solid parts can be used.
I have just open the wrong assy, i believe.
Actually i don't know which is menat to be the main assy.
Admaiora
Ahhh I see where your going!
Yep Bianca you can only edit the One with "FrameGenerator" in it's name.
The other one has a copy of it inserted in it. (the one with the copy produces the error message)
Thanks Admaiora!
In truth it shouldn't matter which of the two you edit since they should be one file.
When you edit the Frame from the "Main" file it should link up with the "Frame" file. (Framegenerator)
In your file it doesn't do that when you select the longer members the file seems disconnected from the Main file. (some of the smaller member still work)
The Longer frame members can be edited with no issue in the "FrameGenerator" File.
So somehow the Longer members 63, 64, 65, and 66 became disconnected with the frame. (regenerating them does nothing).
I guess you have 2 options,
1. Delete the Problem members, and recreate them in the Main assembly (it should join with the Frame Assembly file, not create a new one)
2. open the File from the "FrameGenerator" assembly to make your edits
I hope this helps,
James
Hi all,
Thanks for your replies. I tried deleting the long members and recreating them in the TubeWeldmentFrameGenerator assembly, but receive the same error message when attempting the miter (see Below) and so was not able to complete the miter. I am editing the FrameGenerator file and not the parent assembly for the frame-generated part.
As for which assembly is my main assembly, the TubeWeldment.iam is the parent, with the TubeWeldment.ipt and TubeWeldmentFrameGenerator files as childs.
What I have found is that I can miter the long piece if I change it to 3 short pieces, which I do not want to do. So the error is the result of merging the 3 line segments into 1 and creating the long piece. Is there a simple way to combine three short pieces that have the end treatments I want into one long piece as a workaround?
Hi Bianca,
If you use "Insert Members between points" it will create a frame member between the 2 points. No merging required.
When I recreated the frame members in your "Main" assembly they worked fine for me.
How were you creating the long members?
I hope this helps,
James
Hi James,
Thanks, that did the trick. Strange that merging them creates a problem, but I will be happy to use the two endpoints option to successfully miter the long tube members.
Thanks for your help,
Bianca
No Problem,
Glad I could help.
James
