Is there anyone out there that knows what controls the font style used in dialog boxes. Such as the Project folders dialog box?
I had to reinstall Inventor 2012 and the fonts have changed. it is no big deal. I just don't like it.
P. Brooke
Solved by Curtis_Waguespack. Go to Solution.
Hi pbrooke,
If you go to the Tools tab > Application Options button > General Tab, and look for the Text Appearance setting. I think that is what you're looking for.
I hope this helps.
Curtis
Hi Curtis,
I saw that in applications, but wasn't sure if that was it.
I will give a try and see what happens.
Thought it might be a windows thing.
P.Brooke
Curtis,
That is the place to change fonts.
thanks for your help.
Also, do you know what the font default setting is?
I don't know what kind of font I had before.
I guess I will have to pick a font that is easy on the eyes.
Pbrooke
Hi pbrooke,
The default text font is Tahoma set at size 8.
I hope this helps.
Curtis
