If I create an assembly for a library, do I have to create positional reps before saving it to the library folder? I would like to modify the overrides on a library assembly. Is this possible? I really dont want to lock in the positional overrides - think of a flexible cylinder assembly used in multiple assemblies. The "extended" length of the cylinder could be different. How to do?
Solved by mcgyvr. Go to Solution.
I guess you have setup a non-editable library in your project file..
A cylinder could be done using constraint limits and thats it.. You don't necessarily need pos reps..
Also many people simply make a new project that allows them to edit library files..
If I use constraint limits for the cylinder assembly, does this give me free motion? Can I constrain the cylinder rod end to another component to have it in various positions of extensions? I assumed it being a library part I could not do this... I will try this when I have time. Thanks for the response.
Confirmed:
1. Create a project file that enables you to modify library parts - I did this by setting the library path as my standard workspace, no "library" defined.
2. Create an assembly with constraint limits - I used the new "joint" command with a cylindrical sliding fit - with limits set. The idea is to set the limits of a moving part, but not to lock it in to one position.
3. Go back to the standard project file and insert your new assembly - IMPORTANT - set it as a flexible assembly. This will allow you to constrain it to other moving parts. The best part is the sliding constraint limits - this allows you to "check" a design to see if it falls within the limits.
Thanks mcgyver!!
