Inventor Forum
Flat Pattern with Rib features
3 REPLIES 3
gcross
1650 Views, 3 Replies
My flat pattern of a sheet metal part fails when I added strenthening Press ribs to the middle of the part using an iFeature.
I know Inventor is not capable of flattening embossed sheetmetal but is there a way to still get the flat pattern & ignore the formed areas?
Seems to me I was able to add some model features in the past like bosses, extruded holes KO's etc & I could still make a flat pattern.
I know I can use derived part to do it but that adds complications.
Gary
IV 2012 SP2
Tags (1)
3 REPLIES 3
JDMather
in reply to: gcross
Use sheet metal Punch tool for those ribs.  (a Punch tool is a special iFeature)
gcross
in reply to: gcross
Hi JD,
Is it as simple as adding a center mark to the Press Rib ide file &moving the ide into the punch folder from the other folder or do I need to create a Press rib tool from scratch? This is a compicated iFeature tool & I'm not sure about being able to reproduce it.
Gary
JDMather
in reply to: gcross
A little more to it (not much) than adding center mark and location.
When you create the iFeature there is a tickbox for Punch tool.
I always create my iFeatures as Punch tools whether they really are punches or not.
