Hello fellow Inventor users
I am working with an assembly that has a mixture of Solids and Surfaces. The surfaces are a problem
because when I generate a drawing, the surfaces hides details that I want shown. I want to uncheck
their visibility however if I take my curser and hover over the surface or edge of the surface on my assembly,
I get no response. I have to go to the parts tree, expand each part, look for surfaces to see if its the one I am
looking for to turn off. I know there must be an easier way that I don't know about. Does anyone have any
suggestions? Any tip is greatly appreciated. Thanks
Randall
Inventor 2013, Windows 7
Solved by Cadmanto. Go to Solution.
Try using these tools to see if you can select items better.
Thanks. I tried the filter for surfaces and faces and it worked. I was trying several of the filters and I don't know what I did but when I went back and tried finding the surface in the browser, I got an error message "Selected Object
could not be found in the Browser. It may be filtered off." How do I clear the filter selector?
Sorry for being a pain.
Sincerely
Randall
Select "Component Priority" at the top of the list. That is the default one.
Awesome. Glad I was able to help.
