I know that everyone does this, but do you delete your temp files and defrag
on a regular basis? Temps have a nasty way of srewing up files.
Dennis
Dennis Jeffrey, Inventor 9/10 Professional user
Autodesk Inventor Certified Expert
Autodesk Product Consulting and Training
Omicron Electronics - Center for Design Excellence
http://www.omicronmi.com
http://www.design-excellence.com
260-312-6188
"Nathan Los (Autodesk)" wrote in message
news:4830692@discussion.autodesk.com...
All,
I wanted to post an update on the status of the issue reported by Sean. We
have acquired his dataset and video of the save behavior and currently have
members from a number of teams working to diagnose the cause.
To clarify, this thread has covered two different topics: the dialog which
prompts you to save dependent documents (which Matthias described), and the
single-file save prompt for the top-level assembly (which Sean described).
As far as I know, the issue that Sean and his colleague encountered is
isolated to their computer systems. If anyone else has seen this issue,
please post any details you have to the newsgroup.
I'll be sure to relay all relevant newsgroup posts to the developers doing
the investigation. Thank you for your patience while we investigate this
issue.
Nathan Los
Autodesk Inventor Framework Team
"Sean Dotson" wrote in message
news:4826278@discussion.autodesk.com...
> Here is an interesting one. In R9 we close an assembly. It prompts us to
> save the file. We save Yes. It saves but does not close. You can do
> this as many times as you want but the file will not close.
> If you say NO the files closes. (We all held our breath as we reopened it
> to find that it really did save those other times).
> Not a huge deal but we are seeing it on one machine in particular.
> Sean Dotson
> RND Automation & Engineering
> www.mcadforums.com
