All,
Out of curiosity, do you see different behavior when you change the Tools >
Options > Assembly > Defer Update setting?
Matthias, I have forwarded your sequences on to the developers who are
investigating this issue.
Thank you for your help.
Nathan Los
Autodesk Inventor Framework Team
"Matthias Julius" wrote in message
news:4827924@discussion.autodesk.com...
> Nathan Los \(Autodesk\) writes:
>> Also, if you know of a particular sequence of steps that causes the issue
>> to
>> arise, that list would be very helpful in our investigation.
> - open an assembly
> - modify a referenced component, do not update the assembly
> - close the assembly, IV will ask whether to save or not
> - click yes
> - in the save dialog the default for saving the assembly will be "No"
> - click OK
> - IV will save the modified component and not close the assembly
> or:
> - open an assembly referencing a library component that needs to
> update while opening (that is the case with most of my assemblies
> that use library iParts)
> - save the assembly, the library parts will not be saved by default
> - click Yes when asked to save
> - click OK
> - IV does not close the assembly
> In short, IV does not close a file when in the Save dialog the Save
> option for that file was set to "No".
> This behavior was introduced with IV9.
> Matthias
