I managed to change a setting to where my files are being saved in a library folderand I can't edit them. I don't wish to continue with this nonsense. I want to be able to edit the files. I am not using a vault but still get a message that the file I am trying to open is not signed out to me. How did I manage to mess my settings up this badly. I don't remember changing any of my settings. Help. Thanks Gary
Solved by mcgyvr. Go to Solution.
Manage your project and remove that location from the libraries section..
I am in desperately need help with this issue. Can someone please help me the steps to resolved this issue?
edit your project file and remove that folder from being listed in the "libraries" section of the project file.
I should have mention I've only been using inventor since this past November. can you elaborate the steps for me a little bit? 🙂
thanks again
I am having the issue as well.
I have went to the "library" section under edit projects, but the file folder within is red and I am unable to remove that folder from being listed.
Ideas?
May I add this started to happen when I Imported a component from Revit '13
Open Inventor>Click on Projects>Select the Project Name your Project is listed under>In the bottom window, it will show "Libraries", expand that node>your Project may show in red, click on it>Than to the left it will have a subtract button or remove>Click it.
These are the steps I did to resolve my issue.
