Inventor Forum
Fastener Library setup under Tools
7 REPLIES 7
Message 1 of 8
abscissa
746 Views, 7 Replies
Hi Group, I can't seem to setup the fastener lib. under the Tools menu because it is not showing up(not here). I have tried reinstalling it but it still is not here...what am I missing...it was setup for this assembly before
Ron
7 REPLIES 7
Message 2 of 8
in reply to: abscissa
The fastener library needs the specific name as
shown when installing.  But why use the library when it is so much easier
to use iPart hardware from
href="http://www.cbliss.com">www.cbliss.com
   After all you can
both change the length of a bolt and also change the size without
reconstraining.
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
Hi
Ron
Message 3 of 8
Do you get any mention of " Fasteners" at all
under tools? If yes Make a library named "_Inventor Fastener Library V?" What it
says in fastener set up under tools/ If no it is not installed, this is a
separate install under 5.3. If you installed it look in programs/AutoDesk/ and
there should be a fastener folder, if its not there try repair program or
uninstall IV and reinstall.
Laurence,
Power is nothing without
Control
Hi
Ron
Message 4 of 8
abscissa
Hi Laurence...Here is no mention of " Fasteners" at all under tools...and no matter what I seem to do I can't get that icon or menu to load. I haven't had a problem with it in the past today is just one of those day that nothing seem to be going right.
Ron
Message 5 of 8
Have you tried reinstalling fasteners from 5.3 CD?
uninstall first, is this network?
Laurence,
Control
Hi
to be going right.
Ron
Message 6 of 8
abscissa
No..I'm working local and all is install local not network I will tried reinstalling. Should this be stalled as a user or do I have to install it as admin. IV5 sp2 Win2k sp2
Message 7 of 8
check "Add-ins" under tools and make sure
"&Fasteners" is loaded on startup.  Also make sure there is a line in
you project file in the library search paths that is named: _Inventor Fastener
Library V1
No..I'm
Win2k sp2
Message 8 of 8
abscissa
I have reinstalled the fastener library and check "Add-ins" and the "&Fasteners" is loaded on startup. There is also a correct line in my projects file in the library search paths that is named: _Inventor Fastener Library V1. I load up IV and that still is not sign of the Libray under tools ... weird.
Ron
