Is there any way to set Fast Open as the default? I am having to open hundreds of files and do nothing more than take a quick look at them and then print them. Each file I have to make sure it is clicked on in the open dialog (I can't paste in the filename) and then open options and check Fast Open. Am I missing the setting in App Options somewhere, or is there a registry hack to change it?
Solved by ruthsteed. Go to Solution.
I don't think it is possible.
But i leave the last word to who know it for sure.
Admaiora
Sorry, but unfortunately the setting you want doesn't exist. It's an interesting idea, though. Would a sticky option in the options dialog itself fit your purpose? This would just save the setting until you changed it or exited Inventor. I think it would be easier to find and use than an application option.
In the meantime, though, here is a bit of VBA code that might help. Paste this VBA code into a module in your default project, then use the Customize command (Tools>Customize) to add a button to the environments you'd want it in (Choose "Macros" in the "Choose commands from" dropdown, then select "FastOpenDrawingCmd" and add it to one or more tabs). I'd recommend the "Zero Document|Get Started" and "Drawing|Place Views" since these are the default tabs when no documents are open or when a drawing is opened, but you can add as many (or few) as suit your purposes. The button added will bring up a file dialog for selecting drawings to open. Any Inventor drawings selected this way (including multiple selections) will be opened using "Fast Open".
'>>> Snip VBA here
Sub FastOpenDrawingCmd()
Dim oDlg As FileDialog
Dim bExpress As Boolean
ThisApplication.CreateFileDialog oDlg
oDlg.DialogTitle = "Open Drawings Using FastOpen"
oDlg.filter = "Inventor Drawings (*.idw)|*.idw"
oDlg.MultiSelectEnabled = True
oDlg.ShowOpen
If oDlg.filename <> "" Then
Dim filename As String: filename = oDlg.filename
Dim options As NameValueMap
Set options = ThisApplication.TransientObjects.CreateNameValueMap
options.Add "FastOpen", True
Dim pipe As Integer
Dim strFile As String
Do
pipe = InStr(1, filename, "|")
If pipe > 0 Then
strFile = Left(filename, pipe - 1)
filename = Right(filename, Len(filename) - pipe)
Else
strFile = filename
End If
ThisApplication.Documents.OpenWithOptions strFile, options
Loop While pipe > 0
End If
End Sub
'>>> Snip here
Hope this helps,
Ruth Steed
Inventor Development
