Inventor Forum
Fan Rotation Animation
4 REPLIES 4
2022 Views, 4 Replies
Sorry if this seems too easy to be posted as a topic, but I am very new to the animation of Inventor. I am using Inventor 2008 and I am trying to get the blades in this centrifugal fan to rotate for an animation. Ideally I would like for the fan to slowly speed up, but just getting a rotation movement would be a start.
Hoping somebody can help. Thanks
4 REPLIES 4
JDMather
I didn't actually animate it to test the results - but this should get you started.
Go to Inventor Studio and run the Play Animation.
JDMather
You are going to want to experiment with the Acceleration of the Drive This angle constraint and the number of revolutions and time. I suspect it will never appear entirely correct until the animation is rendered.
Thanks for this JD. Great help. Its exactly what I need! Seems so obvious now. Once rendered, this looks pretty good! cheers
JDMather
Glad you figured it out from the little information I supplied. If you have any questions hollar back.
