Inventor Forum
Face extend
3 REPLIES 3
Henrik_Lo
452 Views, 3 Replies
Face extend
HI
Is it possible to extend the curved face of the solid, straight up to the new not curved face.
It need to be a solid
Regards
Henrik
3 REPLIES 3
JDMather
in reply to: Henrik_Lo
Are you aware the corners will cross over before you get to that surface?
Do you have the original geometry from which the Base was created?
SBix26
Delete the existing 3D sketch (not sure what its purpose is).  Create a new sketch on the flat surface, project the perimeter of the curved surface, then extrude to next.  It makes a rather odd-looking part, because the lower section has a significant draft, the upper part doesn't.
Henrik_Lo
in reply to: SBix26
HI Seem fine to me, just as I need, thanks, the part is for a Mold part.
Regards Henrik
