Inventor Forum
FORMAT TEXT NOTES
3 REPLIES 3
luismestre
1812 Views, 3 Replies
FORMAT TEXT NOTES
Hi all,
Today my question is related to text format.
Is possible to use the tab key to format the text or should we use the space bar key and align the text again by eyeball?
Regards
Luis Mestre
Luis Mestre
Oil&Gas Sr.3D & Subsea/Structural Designer
"Autodesk Autocad/Inventor & 3D Studio Max"
Email:lmsmestre@gmail.com
3 REPLIES 3
in reply to: luismestre
See Attached IDW ( 2009)
The simplest way to format text in Inventor is to create a Word document so
that you can:
1. Use tabs
2. Use numbering of Items
3. Format your document any way you wish
Then copy and paste from Word into Inventor. WordPad also works.
Dennis Jeffrey, Autodesk Inventor Certified Expert
Autodesk Manufacturing Implementation Certified Expert.
Instructor/Author/Sr. App Engr.
AIP 2008 SP2, AIP 2009 PcCillin AV
HP zv5000 AMD64 2GB
Geforce Go 440, Driver: .8185
XP Pro SP2, Windows XP Silver Theme
http://teknigroup.com
wrote in message news:6020045@discussion.autodesk.com...
Hi all,
Regards
Luis Mestre
janitor1
I have copy and pasted as well as inserted into Inventor as an object. The object inserted with the link option works well, especially since you can open the text of the word file from inventor and make changes that update in Inventor. If you so not see the text in your drawing, go to the tree and turn visibility on the inserted word document using right click. But, note that strange things happen if you change the margins.
Steve
IV11 sp4
dazataz
Doesn't work for me. I want to do a Number list with indents and 2nd line indenting like Autocad and the attached file. Copy/Paste into a Text Box in Inventor stripped all of the indents and tabbing...
Am I missing something?
Is there another way to insert the text rather than into a text box?
