I am running a simulation where the material is modified in material editor (specifically the yield strength and tensile strength) and when I create the report, it shows the defalt physical properties. What am I missing that is causing this issue?
An assembly file (*.iam) is only a list of hyperlinks to the part files (*.ipt) and a record of assembly constraints (and a bit more).
You must include the part files.
Are you aware that the parts are assembled in interference?
I didn't get past that.
Yes, I am aware. the point load from the support ring to the head was the load of concern, I was asked to increase contact surface. I did it that way in a hurry, but I now realize that may be adversly affecting the analysis in comparison to a chamfer?
