Inventor 2013. I have completed a part file with a family table defined in it. I check this part into vault. When I search for this part in vault it seems like it has taken the part number and the description from the first line in the family table and assigned it to the main part file. To me this is confusing because it looks like there are two items that are the same. Is this the way it is supposed to work or am I missing something.
That is only the member name. What it did was fill in the property of that name. The file name should not have changed.
Can you post a screen shot of the factory table? You call it a familt table when it is really called the factory table. The family table term is used within the content center editor.
If this solved your issue please mark this posting "Accept as Solution".
Or if you like something that was said and it was helpful, Kudos are appreciated. Thanks!!!!
