I've checked everywhere else for a solution but none apply to me it seems. My keyboard shortcut for returning to the home isometric view (F6) is not working. F3, F4, & F5 all work fine. I've tried returning the cursor focus back to the model window and that doesn't work. I also made sure the shortcut is actually listed in the Customize menu, I even reset all to default in case something was changed. Any suggestions? Thanks
Hi hbohm,
Thanks for your reporting !!!
I have tried to reproduce this issue, but I am not seeing the same behavior as your have reported. Another way is go to Ribbon, View tab, Navigate panel and click Home View button, you can try it.
Kevin Li
Quality Assurance Team
Autodesk, Inc.
Thought the keyboard might be a possiblity at first but the F6 key works in other applications. Also, I noticed now that when the F6 shortcut doesn't work, CTRL-Z (UNDO) doesn't work either. I have confirmed that no other running applications have any control over those commands/shortcuts.
I found this thread because I was having the same problem and searching for a solution. The F6 key just up and quit working in Inventor. It still worked fine in anything else.
In Inventor 2013, I went the Tools ribbon tab, Options panel and selected Customize. In the Customize dialog box, I clicked the Reset All Keys button and answered Yes to continue. I then clicked Apply and OK. That fixed it for me. Your mileage may vary.
Note, if you've done much keyboard customization in Inventor, that'll all be gone. But it's not that difficult to reprogram them.
So here I am almost a whole year later with a new version of Inventor and even a brand new computer, and my F6 (Home), CTRL+Z (Undo), & CTRL+S (Save) keyboard shortcuts still do not work. I've been searching off and on through-out the previous year, and cannot come across a solution.
I don't carry any customized files forward between each release of Inventor except for the drawing, part, & assembly template files that we have set up for our company. I'd still like someone to shed some light on this issue, at this point I've been used to clicking the home button on the viewcube, so it's more of a curiousity issue than anything. I like my shortcuts, what else can I say?
Wow, I thought ctrl-S and ctrl-Z were pretty much hard-wired into Windows. I know you said F6 works in other applications, how about ctrl-S and ctrl-Z?
If you go into the Tools tab, Options panel, click Customize and go to the Keyboard tab, are those keys defined?
The loss of shortcut key will/can also occur when the memory usage meter in Inventor get to 80% to 90% capacity of memory used Ergo the less memory you have the quicker this situation occurs.
A work around it this is to increases the "Paging file size" while this is not as good as adding more RAM it dose have some positive effect
Yeah, I use Autocad Electrical all day long and ctrl+s, ctrl+z, ctrl+shift+c, etc. are all second nature to me. They work fine everywhere else. Once I need them in Inventor they don't work. To be clear, I'm not saying that once I open Inventor that I lose functionality in all other programs too, just in Inventor.
Those shortcut keys are all defined in the customize menu. I even tried assigning it as a shortcut to my extra mouse buttons and it wont work. I've also tried assigning an alias key to the Home command and that didn't work. I have clicked reset to default on numerous occasions to no avail.
The amount of RAM shouldn't be a problem, I have 8GB total and when I'm using Inventor it's usually the only program open. Also, the parts & assemblies we work on here are never very large. The RAM usage meter never gets over 40-50% unless I'm doing some photo rendering or video walkthroughs.
Very briefly, once in a blue moon, it will all the sudden work for some reason, but as soon as I close out or switch to a new model/assembly it doesn't work again. Thanks for all your responses.
Hello everybody...
I know this thread is already pretty old, but I want to post the solution that worked for me.
Actually... it is a kind of a wired behavior in Inventor 2012.
Our company just switched from Inventor 2009 to Inventor 2012 and… I don’t like it at all. I hate Microsoft for coming up with this awkward Ribbon interface and now all major software developer following this crap – IMHO.
Anyway… what I figured is… on the title bar at the right side is the “Info Center”. There is on the left a search bar to type in a keyword or phrase. Left of this field is an arrow, which toggles between showing this the search bar or not.
If this field is toggled off, the F6 – Home View function will not work. If you go back and toggle it on, the F6 key will work again. At least that solved the problem for me.
Hope this can help somebody, even thought, that most people working with newer versions now.
I recall that someone else figured that out several years ago. If you're curious you could do a little searching to find out which version(s) that applied to. It hasn't been a problem for the last several versions now.
Question: why on earth are you "upgrading" to a version so old that it's no longer supported?!
Sam B
Inventor Professional 2016 Update 2
Vault Basic 2016
Windows 7 Enterprise 64-bit, SP1
Good question, the first thing I would do is make sure that all Service Packs and Updates have been installed.
