"Willy Driessen" <
href="mailto:wdriess@iae.nl">wdriess@iae.nl> wrote in message
href="news:ABC227AB6B966AEDFAE22FA7293A6383@in.WebX.maYIadrTaRb">news:ABC227AB6B966AEDFAE22FA7293......
I'm trying to use a master sketch which
comes with a derived part for extrusion.
This (derived) sketch containts about 50 lines,
all fully contstraint. The sketch forms several "extrudable"
area's.
Starting the extrude command let's me
wait 19 seconds before the sketch appears again.
Question:
1. how to reduce this waiting time (settings ?)
2. some area's are not to select (the +
sign not to show them), although in the derived part
itself they are.
Any suggestions ?
W. Driessen
System:
Dell Workstation 350
2.4 GHz
1 Gb Ram
Quattro 750 XGL
"Udaya Gunasena (Autodesk)" <
href="mailto:udaya.gunasena@autodesk.com">udaya.gunasena@autodesk.com>
wrote in message
href="news:68096BAFEDD7B2502C7295BB0FAFCF50@in.WebX.maYIadrTaRb">news:68096BAFEDD7B2502C7295BB0FA......
You may be able to reduce the time by creating a
new sketch coincident with the derived sketch,
and then projecting the relevant curves from the
derived sketch to the new sketch. Turn off the
visibility of the derived sketch before you start
the extrude command.
You may also be able to reduce the time by
changing the "style" of particular derived sketch
curves
from "reference" to "construction."
"Willy Driessen" <
href="news:ABC227AB6B966AEDFAE22FA7293A6383@in.WebX.maYIadrTaRb">news:ABC227AB6B966AEDFAE22FA72......
area's.
Question:
itself they are.
Any suggestions ?
W. Driessen
System:
2.4 GHz
1 Gb Ram
Quattro 750 XGL
"Willy Driessen" <
href="news:079152CC423929F086DDBC9D9AD35717@in.WebX.maYIadrTaRb">news:079152CC423929F086DDBC9D9AD......
Hi, Udaya. Your story about the "style" brings me
to next test:
My master sketch containts about 6 points as
a result of projecting normal lines (perpendicular to master sketch plane),
which belongs to other sketches in the master. So changing these points style
is impossible. But . . the thing I tested was to delete these points and
fix some points in my master sketch to constraint everything. My
'extruding-waiting-time' was reduced from 20 to about 2 seconds
!!!! FYI: the linked sketch was derived as well, and
invisible.
So most probably the link between different
sketches is processor consuming ? ? ? ?
Regards, Willy
wrote in message
href="news:68096BAFEDD7B2502C7295BB0FAFCF50@in.WebX.maYIadrTaRb">news:68096BAFEDD7B2502C7295BB0......
a new sketch coincident with the derived sketch,
the derived sketch to the new sketch. Turn off the
start the extrude command.
curves
from "reference" to
"construction."
"Willy Driessen" <
href="news:ABC227AB6B966AEDFAE22FA7293A6383@in.WebX.maYIadrTaRb">news:ABC227AB6B966AEDFAE22FA......
lines, all fully contstraint. The sketch forms several "extrudable"
area's.
Question:
itself they are.
Any suggestions ?
W. Driessen
System:
2.4 GHz
1 Gb Ram
Quattro 750
XGL
