Inventor Forum
Extruding derived sketch very slow
5 REPLIES 5
478 Views, 5 Replies
I'm trying to use a master sketch which comes
with a derived part for extrusion.
This (derived) sketch containts about 50 lines, all
fully contstraint. The sketch forms several "extrudable" area's.
Starting the extrude command let's me wait 19
seconds before the sketch appears again.
Question:
1. how to reduce this waiting time (settings ?)
2.  some area's are not to select (the + sign
not to show them), although in the derived part itself they
are.
Any suggestions ?
W. Driessen
System:
Dell Workstation 350
2.4  GHz
1 Gb Ram
Quattro 750 XGL
5 REPLIES 5
Hi Willy,
One of the drawbacks of a single sketch that has multiple extrusions is that
Inventor has to 'find' all the possible extrudable areas, and this can take
a while. I use master sketches with many possible extrusions, and have seen
the problems you're describing. I have turned in a few cases where Inventor
couldn't find the extrudable area in the derived part when it could find it
with no problems in the master. Some of it has to do with the sheer
complexity of a master sketch. We are doing things with Inventor that are
beyond what the designers envisioned.
There is something you can do that may help both your problems. I've
noticed that it apparently matters to Inventor just how a shape is drawn.
If you are drawing a polygon, and start at a certain point, then proceed
through a series of points, and finally click back where you began to close
the profile, Inventor will have no trouble finding that area to extrude. If
you draw the same polygon in parts, starting and stopping the line command,
Inventor still does ok. But draw one of those line segments backwards in
relation to the others, and you just might have problems when you get that
profile into a derived part. I've never seen this happen when there was
only one profile in the sketch, but get 20 possible profiles in the same
sketch, and things can get a bit rough. I have had cases where I deleted a
line and redrew it in the opposite direction from the original, and suddenly
the area was extrudable. A slightly different constraint scheme for that
profile can also cause it to suddenly start working. It's possible in a
master sketch to have several lines coming together at a single point.
Example:
________
| |B
|_______|___C___
A | |
|_______|
The two extrudable rectangles meet at their corner. If the endpoint of line
A is actually constrained to the endpoint of line C instead of line B,
Inventor seems to have to work harder to compute the upper left rectangle.
Are the endpoints constrained together in a way that makes it easy for
Inventor to find the extrusions? Theoretically it shouldn't matter, but the
fact remains that I see far fewer profiles fail to extrude, and my
extrusions compute much faster since I started paying particular attention
to how I constructed my sketch profiles.
Another thing I've noticed: If you draw a rectangle, and either right-angle
or parallel constrain the lines together (normally, Inventor does this
automatically), then add dimensions between the lines to define the size of
the rectangle, there is actually a sort of overconstrained condition going
on. Inventor allows it, but putting a dimension between two lines is kind
of the same thing as saying that they're parallel, right? Normally this is
no problem, but when you push the envelope with a master sketch setup, it
can become an issue. Another weird asci example:
a ____W______b
X| |Y
|___________|
c Z d
If you already have parallel or right-angle constraints between lines W,X,Y
and Z, and then you put a dimension between lines X and Y, you've actually
slightly overconstrained the sketch. For a simple rectangle like this, it's
not a problem, but in a complex master sketch I've seen it cause issues.
The answer is to place the dimension between line Y and point a instead. It
does the same thing without causing a potential glitch.
If you already have a complex master sketch that you're having problems
with, there is a quick workaround that can help. In the derived part, edit
the sketch you're having trouble with. You won't be able to change any of
the existing lines, since they're all linked to the master, but you can add
lines. If an extrusion isn't solving, trace it's outline with a new set of
lines. The lines you add will constrain themselves to the existing line,
and the profile should solve. Any changes made to the master sketch will
update the lines you added, so adaptability isn't lost.
Cheers,
Walt
"Willy Driessen" wrote in message
news:ABC227AB6B966AEDFAE22FA7293A6383@in.WebX.maYIadrTaRb...
> I'm trying to use a master sketch which comes with a derived part for
extrusion.
> This (derived) sketch containts about 50 lines, all fully contstraint. The
> Starting the extrude command let's me wait 19 seconds before the sketch
appears again.
> Question:
> 2. some area's are not to select (the + sign not to show them), although
in the derived part itself they are.
> Any suggestions ?
> W. Driessen
> System:
> 2.4 GHz
> 1 Gb Ram
> Quattro 750 XGL
You may be able to reduce the time by creating a
new sketch coincident with the derived sketch,
and then projecting the relevant curves from the
derived sketch to the new sketch. Turn off the
visibility of the derived sketch before you start
the extrude command.
You may also be able to reduce the time by changing
the "style" of particular derived sketch curves
from "reference" to "construction."
style="PADDING-RIGHT: 0px; PADDING-LEFT: 5px; MARGIN-LEFT: 5px; BORDER-LEFT: #000000 2px solid; MARGIN-RIGHT: 0px">
comes with a derived part for extrusion.
all fully contstraint. The sketch forms several "extrudable"
area's.
wait 19 seconds before the sketch appears again.
Question:
sign not to show them), although in the derived part
itself they are.
Any suggestions ?
W. Driessen
System:
2.4  GHz
1 Gb Ram
Quattro 750 XGL
Wow, Walt first thanks for this helpful respons. Your ideas about reducing
the complexity to help Inventor find the extrudable areas sounds all more or
les reasonable. This will help me for sure. Although it doesn't give a
software-user much satisfaction how to save the software !!
Your quick workaround is an option (already done), but takes away the
efficiency and power of the master sketch.
By the way should it help to set the Contstraint Placement Priority to
Horizontal/Vertical ? I will test this.
Overall there's still no explanation for the difference in finding
extrudable areas between derived parts and masters.
Regards, Willy
"Walt Jaquith" wrote in message
news:BC94C78F2FF0418DDA1B8DB501A34C25@in.WebX.maYIadrTaRb...
> Hi Willy,
that
take
seen
Inventor
it
close
If
command,
a
suddenly
> Example:
> ________
> | |B
> |_______|___C___
> A | |
> |_______|
line
the
right-angle
of
is
> a ____W______b
> X| |Y
> |___________|
> c Z d
W,X,Y
it's
It
edit
add
of
> Cheers,
> Walt
> extrusion.
The
> appears again.
> > Question:
although
> > Any suggestions ?
> > W. Driessen
> > System:
> > 2.4 GHz
> > 1 Gb Ram
> > Quattro 750 XGL
Hi, Udaya. Your story about the "style" brings me
to next test:
My master sketch containts about 6 points as a
result of projecting normal lines (perpendicular to master sketch plane), which
belongs to other sketches in the master. So changing these points style is
impossible. But . . the thing I tested was to delete these points and fix
some points in my master sketch to constraint everything.  My
'extruding-waiting-time'  was reduced from 20 to about 2 seconds
!!!!   FYI: the linked sketch was derived as well, and
invisible.
So most probably the link between different
sketches is processor consuming  ? ? ? ?
Regards, Willy
changing the "style" of particular derived sketch
curves
area's.
Question:
itself they are.
Any suggestions ?
W. Driessen
System:
2.4  GHz
1 Gb Ram
Quattro 750 XGL
Hi Willy,
The link between the sketches or between the
derived and base parts should not
have any effect on the time you see. It simply
depends on the data internal to a
sketch.
The algorithm for finding the closed regions is
optimized for the kinds of sketches
that you usually associate with features. If it
detects a particular characteristic
(it's hard to describe this without describing the
algorithm, but "typical" sketches
would not have this characteristic) it decides to
do a more rigorous (and expensive)
search for the closed regions. This probably
explains the significant difference
you were seeing in the performance.
The reduction that you saw was probably due to the
change of the derived sketch
after you made changes to the base sketch. There
may be subtle differences between
an updated derived sketch and a freshly derived
sketch of the same base sketch.
to next test:
a result of projecting normal lines (perpendicular to master sketch plane),
which belongs to other sketches in the master. So changing these points style
is impossible. But . . the thing I tested was to delete these points and
fix some points in my master sketch to constraint everything.  My
invisible.
Regards, Willy
a new sketch coincident with the derived sketch,
the derived sketch to the new sketch. Turn off the
start the extrude command.
curves
from "reference" to
"construction."
lines, all fully contstraint. The sketch forms several "extrudable"
area's.
Question:
itself they are.
Any suggestions ?
W. Driessen
System:
2.4  GHz
1 Gb Ram
Quattro 750
XGL
