Inventor Forum
Extrude to in Assembly Creates Work Plane
5 REPLIES 5
KimBruns
301 Views, 5 Replies
I'm pretty new to Inventor and am stuck on this one.
I'm creating a top-down assembly of a tank.  The bottom has 3 channels 60" (one 3", one 4" , one 5") spaced evenly apart with a floor plate that lays on top, so it is pitched.  I created that subasm with the Frame Generator.  Then I offsetted a work plane from the bottom of the channels up to a given height, say 42" to create work plane, let's call it, WorkPlane_Tank_Hgt.  Then I extrude plates down to the pitched floor to make a square box, so the plate in front is taller than the plate in back and the plates on the sides are pitched on the bottom.
The problem comes when I extrude to the floor plate, it creates a work plane at the floor plate (WorkPlane_Floor_Plate) so when I change WorkPlane_Tank_Hgt, WorkPlane_Floor_Plate moves off the floor plate and my walls don't change.
Anyone have an idea on this?
Thanks,  Kim
Product Design Suite 2016
Windows 7 Professional x64
Intel Xeon E31270 @ 3.4GHz
16GB RAM
NVIDIA Quadro 2000
5 REPLIES 5
KimBruns
in reply to: KimBruns
Or I guess my problem is how do I attach the Work Plane to the pitched floor?
Thanks for any help
Kim
16GB RAM
NVIDIA Quadro 2000
blair
Possible to post a screen capture
Inventor 2020, In-Cad, Simulation Mechanical
Just insert the picture rather than attaching it as a file
Delta Tau Chi ΔΤΧ
KimBruns
in reply to: blair
Yes I can.  I deleted the walls last night and was going to try again.  When I do I'll see if I can get it to work otherwise I'll post a pic.
Thanks,  Kim
16GB RAM
NVIDIA Quadro 2000
KimBruns
Here's an image of the tank.  The top (brown) WP is an offset WP create from the asm XY plane, ie. it is the Tank Hgt.  The blue WP (Work Plane2) was created when I selected the floor (gray plate) as the extrude to point.  When I change the Tank Hgt, (brown WP) the blue WP moves.  How do I keep the blue WP fixed to the floor?
Thanks for any help.
Kim
16GB RAM
NVIDIA Quadro 2000
blair
Wouldn't a work-plane attached to the plate floor solve your problem
Delta Tau Chi ΔΤΧ
