When I export from Inventor professional to an STL file for 3D printing. Everything exports ok exept threads. I have a model with M10 and M4 threads which never show on the STL file. Is there an option I need to tick to make sure they convert?
Thanks for any help
Cheers
George
Solved by sam_m. Go to Solution.
George,
Welcome to the forum.
Are you creating the threads as real threads or as cosmetic? If they are just cosmetic threads then they are for on screen appearance only. Kind of like textures and colors.
i think, what he means is - how have you made these threads?
if it's with the hole/thread tool then all you see is a cosmetic thread in Inventor as a texture - if this is exported to a stl/stp/igs/etc it will only show a hole of the nominal diameter (depending the options set).
The only way to export a thread in a stl is to actually model it with a coil cutting the profile down the hole - is this what you have done?
Sam M.
Inventor and Showcase monkey
Please mark this response as "Accept as Solution" if it answers your question...
If you have found any post to be helpful, even if it's not a direct solution, then please provide that author kudos - spread that love 😄
Hi
many thanks for your advice.
I put the threads in the hole using the thread tool. I will take your advice and try using a coil to cut the threads.
Cheers
George
@g.lawson wrote:Hi
You should be using the Hole command for threaded holes, not the Thread command.
In any case you need to model the actual theads.
The CADWhisperer YouTube Channel
You need to do a "Save copy as" to get the full list of filetypes:
"I" logo at top left -> Save as -> Save Copy as
(or use Export -> CAD Format)
Then use the "save as type" drop-down and select STL 😉
remember to check the export options (click the options button on the "save as" dialog) to check you are exporting in the same units as your design, otherwise your print may well come out surprisingly large or small...
Sam M.
Hello!
I made a gear with an inner diameter of .8 inchs. The gear is an IPT and when i export it to an STL, its inner dimension changes to a little more then 2 inches. Why is this and how can i fix it?
As indicated in the previous responses in this thread -
post image of your stl Options.
and how are you verifying the size of the stl part?
