I have tried to export some simple 2D sketches I created in Inventor into a DWG format used in AutoCAD (which I will eventually turn into a DXF file). However, AutoCAD shows a blank dark screen when I open the DWG file. Is there something that I am missing during the export process?
Hi
If you click on the options button at the bottom, he sketches export option is not checked by default, you need to enable it.
I have tried this already and unfortunately, changing the export settings do not make a difference. However, I have solved the problem and realized that my drawings have shifted planes during the export. Is there a way in AutoCAD to correct the shift and move the entire drawing into a different plane? Sorry I am not very well versed with AutoCAD.
