Hi, I have the following problem when I try to export an .idw file to .dwg
I use the save copy as menu, and after I chose the .dwg extension file and
when I click on save appears a dialog box that says:
"Could not open the DWG template file. Please check the path and try again"
I have tried with many options in the option menu of the .dwg extension
file, but nothing happens.
Thank you for your help.
Luis
