I am trying to export an assembly file to Catia V5 and I get the following error: "No more memory is available - attempt to allocate 320 bytes of memory failed. I have listed my system hardware and software below. Thanks in advanced for the help
i3 540 @ 3.06GHz
8Gb
64 Bit 7 Home Premium
Nvidia GeForce GT 240 512Mb
Inventor Pro 2011 Educational Version
Google Chrome
Hi CrateTech,
Thanks for the report !
Seems your memory is used up, can you try to reboot your machine and relaunch Inventor then export it again ?
Kevin Li
SQA Engineer
Autodesk, Inc.
Also check your virtual memory settings in System Properties and how much available space there is on the disk drive where the paging file is located. Both of these things can cause you to run out of memory space even on a 64 bit OS.
