Inventor Forum
Export to Unigraphics/NX?
8 REPLIES 8
Message 1 of 9
MikahB
7121 Views, 8 Replies
I think I know the answer, but would rather open my mouth and appear a fool then keep it closed and leave any doubt.
Can I export from IV 2013 directly to NX?  I've seen several documents indicating there is some degree of "interoperability," but I don't see NX/UG/.prt as an export option.  So, is NX import only?
Mikah Barnett
All Angles Design
Product Design Suite Ultimate 2014
Windows 7 Professional x64
Intel i7-3770k @ 4.5GHz
32GB DDR3-2400 RAM
GeForce GTX 670 4GB
Tags (1)
8 REPLIES 8
Message 2 of 9
blair
in reply to: MikahB
Most software works on the import of differnt formats. They may be able to open Inventor files if their software package is newer than what they are importing.
The best is just to export to a neutral format.
Delta Tau Chi ΔΤΧ
Message 3 of 9
MikahB
in reply to: blair
They just switched from Catia 5 to NX 7.5 and they cannot import my Inventor files directly.  I can continue to send them Catia files, just wanted to make sure I wasn't missing something as I see the NX/UG Translation Add-In - I guess it's import only.
Thanks.
Mikah Barnett
All Angles Design
32GB DDR3-2400 RAM
GeForce GTX 670 4GB
Message 4 of 9
KevinLi-Autodesk
in reply to: MikahB
Hi MikahBarnett3563,
Appreciate your report in this forum!!!
About Inventor 2013 software, your guess is correct that NX import is only supported. I also suggest to use the neutral file format say export your Inventor file to IGES or STEP then open it in NX7.5 as a workaround.
And for your question, the answer is Yes says NX7.5 cannot import Inventor files directly and it can open CATIA V5 files directly. So this is the second way you can choose.
Kevin Li
Quality Assurane Team
Autodesk, Inc.
Kevin-Hongyuan Li
Software Quality Assurance Engineer
Design, Lifecycle and Simulation Product Group
Direct: +86 21 2039 6025
Email: Hongyuan.Li@autodesk.com
Autodesk, Inc.
NO. 130, Lane 91, E Shan Rd
Building 12, Floor 6,
Shanghai 200127, PRC
www.autodesk.com
Message 5 of 9
LOONYLEN
in reply to: KevinLi-Autodesk
Kevin,
Can IV2012 import NX 9 files and can IV2012 files saved in a Catia file format be directly imported into NX 9?
Please advise,
Len
Senior Designer/Cad Administrator
Inventor 2012, w/SP2
Vault Collaboration 2012
Dell Precision T3500, Intel Xeon CPU
W3680 @3.33GHz, 16.0 GB of RAM
Microsoft Windows 7 Pro, 64 Bit Edition
Version 2009, w/SP1
Message 6 of 9
KevinLi-Autodesk
in reply to: LOONYLEN
Hi LOONYLEN,
Inventor 2012 cannot import NX9 version, it only support to NX7.5 and Inventor 2015 can import NX9 version, other format version support can refer to attached document.
Answer to second question is Yes.
Kevin-Hongyuan Li
Autodesk, Inc.
www.autodesk.com
Message 7 of 9
LOONYLEN
Can I use "Save As" to save Inventor 2015 files as Inventor 2012 files? Is there any way of Inventor 2015 files being backward compatable with Inventor 2012?.
Version 2009, w/SP1
Message 8 of 9
blair
There is no ability to Save-As to a older version, due to some features can't be save backwards and re-created in older versions. The only way would be to export the Inventor model to a neutral format such as a STEP or IGES file and then import this into the software we wish to use.
Delta Tau Chi ΔΤΧ
Message 9 of 9
KevinLi-Autodesk
Hi LOONYLEN,
My answer is same with blair.
Kevin-Hongyuan Li
Autodesk, Inc.
www.autodesk.com
