is there a way to export to share with other a custom contente center derived library? (without vault)
Thank you
Solved by cbenner. Go to Solution.
Place the libraries on a Shared (network) drive, and then set each user's Inventor to point to that location. Note in the picture, that my setup is Vault, so I highlighted what you would need to use.
Chris Benner
Inventor Tube & Pipe, Vault Professional
Cad Tips Tricks & Workarounds | Twitter | LinkedIn
Autodesk University Classes:
Going With The Flow with Inventor Tube and Pipe | Increasing The Volume with Inventor Tube and Pipe | Power of the Autodesk Community | Getting to Know You | Inventor Styles & Standards |Managing Properties with Vault Professional | Vault Configuration | Vault - What is it & Why Do I Need It? | A Little Less Talk - Tube & Pipe Demo | Change Orders & Revisions - Vault, Inventor & AutoCAD | Authoring & Publishing Custom Content
