Buenas el error que tengo es este ¿cómo lo puedo solucioar?// Hello this is the error How can I solve this?
Solved by mpatchus. Go to Solution.
Go to your Inventor options and look at the file tab..
Undo should read ...
I make a folder under my C drive called inventor undo and I map to that. This way if the error comes up again I can go to that folder and delete everything and restart inventor. All it is telling you is there is no more space for the undo files to go..
Make sure your C drive got enough space, at least few gb free space. It could be one of the reason fot this message to pop out.
I just got this error on one of my machines (r2013) and Inventor doesn't launch.
Cleaned the referenced Temp and still no luck?
How much free space do you have?
Recycle bin empty?
Whoa,
I thought I had a monster HDD that would never fill up, but that was it. I had no idea that it was almost full.
Now I've got to spend some time taking out the garbage that wasn't in the Recycle bin.
copy the link that the message box shows and open that link. It is usually hidden so cant be accessed directly. Manually delete all the files in the folder and you are good to go!
The fix for the missing error message will be released in a future service pack.
