Solved by johnsonshiue. Go to Solution.
@Vitornis wrote:
I am getting this error below when i try to import two .sat files into my part file.
What version ACIS (*.sat)?
What version Inventor?
Can you attach the files here?
You might have to right click on the filenames and select Send to Compressed (zipped) Folder to attach here.
And try both IE and Chrome.
You could also post to Autodesk360 and then give the link here.
Hi! I have pulled down the files from the shared location. I am able to import them both to Inventor R2015 without a problem. What Inventor release are you on? Could you show me the Import Options you used (Open -> select the SAT file -> Options)?
Thanks!
