Any idea what this error box means? I was trying to constrain this sub-assembly into my main assembly.
I am running 2011
The General System Error is as you can guess a generic error. There is no particular issue that would trigger it. You will want to close the file and Inventor restart and repeat the steps. If you can repeat it in the same assembly I would then create a new assembly with the component you where constraining (and possibly a few more) then give it a try again. If it is repeatable then let us know or since you’re on subscription you can log a case with us.
Charlie
