Inventor Forum
Error Splitting Curved Faces
2 REPLIES 2
sideshowgabe
327 Views, 2 Replies
I'm having trouble trimming two solids and fitting them together. I have a part that consists of two revolutions - an ellipsoid and a curved cone - and I'm trying to embed the cone in the ellipsoid (which I've done) and trim the excess (which I have not been able to figure out). I need to trim the part of the cone that sticks out from the ellipsoid, and trim the part of the ellipsoid that blocks what's left of the cone. So the end result should look sort of like a football with a small bowl flush mounted inside it.
But I can't figure out how to get Inventor to acknowledge the intersection of the two pieces -- I tried to draw an intersection curve in a 3d sketch, but when I try to select a second face it doesn't respond. I managed to include a yellow line that looks like an intersection curve (but apparently isn't) by using the "include geometry" command, but if I try to split the part using that line, I get an error saying that it doesn't fully intersect the faces I'm trying to split (though from a visual perspective it obviously does).
Any suggestions for how to go about this properly would be super helpful. Thanks!!!
2 REPLIES 2
MingweiGao
in reply to: sideshowgabe
I had a look at your provided model and tried to get the result. Below are some ideas of this model:
1. If you want to use multi-solid method, you need to change the Revolution4 feature to another solid, refer to attached picture:Multi-solid.png;
2. I think the 3D curves in here is useless;
3. The better way may use surfaces to trim the solids seperately and combine them together. The details can refer to the attached model;
4. If the result is not your expected, you can change the copied surfaces or adjust the direction of sculpts to get your result.
Hope this can resolve your problem.
Steven Gao
Sr. SQA Engineer
Tags (1)
sideshowgabe
in reply to: MingweiGao
Thank you! Very much appreciated!!
