On Mon, 19 Jun 2006 13:27:43 +0000, mnow <> wrote:
>I have got the same error. here is what you need to do
>Installation Error 1406 when attempting to install Autodesk Inventor®
>Published date: 2006-04-06
>Applies to:
>Autodesk Inventor® Professional 11
>Autodesk Inventor® Professional 10
>Autodesk Inventor® Series 11
>Autodesk Inventor® Series 10
>Issue
>When you tried to install an Autodesk Inventor® product, you received the following error message:
>Error 1406. Could not write value to key
>\Software\Classes\CLSID\{D27CDB6E-AE6D-11cf-96B8-444553540000}\Programmable.
>Verify that you have sufficient access to that key, or contact your support personnel.
>Solution
>This error occurs if you have Macromedia Flash Player 8a installed on your system. This version of Flash Player is newer than the version that is installed when you install Autodesk Inventor®.
>Before you install Autodesk Inventor, you should check to see what version of Flash Player you have installed on your computer. If you have version 8a installed, you should uninstall it before you install Autodesk Inventor. Because Flash Player 8 is installed during the Autodesk Inventor installation, you will have a working version. Future Flash Player upgrades should not adversely affect your Autodesk Inventor environment.
>To correct this issue:
>1. Cancel the installation of Autodesk Inventor.
>2. Close all Internet Explorer browser windows and any other internet browser windows you have open.
>3. On the Start menu (Windows), click Run.
>4. In the Run dialog box, enter C:\WINDOWS\system32\Macromed\Flash\UninstFl.exe to clean all Flash 8a registries. Note: Make sure to enter the entire path.
>5. On the Start menu (Windows), click Settings > Control Panel.
>6. In Control Panel, double-click Add or Remove Programs.
>7. In the Add or Remove Programs dialog box, select Macromedia Flash Player 8. Click Remove. Note: Although Flash Player 8 is listed, this is really version 8a.
>8. Retry installation of Autodesk Inventor.
>If you are still not able to install Autodesk Inventor successfully, please contact Product Support for further assistance.
Problem is, that does not always work.
I had the exact same issue and it turns out that for some reason, that
particular registry key had deny access across the board to modify it.
So not even the uninstall for macromedia could delete it!
The only way I was able to fix it is as follows:
1 - Start regedit
2 - Find the registry key
3 - Right click the key, select permissions
4 - Click on advanced
5 - Check permissions for your account, make sure they are set to Full
Control, if not...change them to full control.
6 - Check owner of the key, your user account should be listed as
owner
So bottom line, make sure you own the key and make sure you have Full
Control under your current user account.
If to both criterias are met, you should be able to delete the key
manually in regedit. Then go reinstall inventor and it should be just
fine.
