I get this error message when trying to launch my application on client station. I have checked the deployment and all the necessary path to the server LMtools and network license manager. My license file is combined into 1 file. It issues licenses to other application but not to inventor or MEP.
The log file is
9:40:50 (lmgrd) -----------------------------------------------
9:40:50 (lmgrd) Please Note:
9:40:50 (lmgrd)
9:40:50 (lmgrd) This log is intended for debug purposes only.
9:40:50 (lmgrd) In order to capture accurate license
9:40:50 (lmgrd) usage data into an organized repository,
9:40:50 (lmgrd) please enable report logging. Use Macrovision's
9:40:50 (lmgrd) software license administration solution,
9:40:50 (lmgrd) FLEXnet Manager, to readily gain visibility
9:40:50 (lmgrd) into license usage data and to create
9:40:50 (lmgrd) insightful reports on critical information like
9:40:50 (lmgrd) license availability and usage. FLEXnet Manager
9:40:50 (lmgrd) can be fully automated to run these reports on
9:40:50 (lmgrd) schedule and can be used to track license
9:40:50 (lmgrd) servers and usage across a heterogeneous
9:40:50 (lmgrd) network of servers including Windows NT, Linux
9:40:50 (lmgrd) and UNIX. Contact Macrovision at
9:40:50 (lmgrd) www.macrovision.com for more details on how to
9:40:50 (lmgrd) obtain an evaluation copy of FLEXnet Manager
9:40:50 (lmgrd) for your enterprise.
9:40:50 (lmgrd)
9:40:50 (lmgrd)
9:40:50 (lmgrd)
9:40:50 (lmgrd) pid 5372
9:40:50 (lmgrd) Detecting other license server manager (lmgrd) processes...
9:40:50 (lmgrd) Done rereading
9:40:50 (lmgrd) FLEXnet Licensing (v11.4.0.0 build 31341) started on allcadserver1 (IBM PC) (2/5/2009)
9:40:50 (lmgrd) Copyright (c) 1988-2006 Macrovision Europe Ltd. and/or Macrovision Corporation. All Rights Reserved.
9:40:50 (lmgrd) US Patents 5,390,297 and 5,671,412.
9:40:50 (lmgrd) World Wide Web: http://www.macrovision.com
9:40:50 (lmgrd) License file(s): D:\Program Files\Autodesk Network License Manager\License\AllCADConsult_ALL_license.lic
9:40:50 (lmgrd) lmgrd tcp-port 27000
9:40:50 (lmgrd) Starting vendor daemons ...
9:40:50 (lmgrd) Starting vendor daemon at port 2080
9:40:50 (lmgrd) Using vendor daemon port 2080 specified in license file
9:40:50 (lmgrd) Started adskflex (pid 608)
9:40:51 (adskflex) FLEXnet Licensing version v10.8.0 build 18869
9:40:51 (adskflex) lmgrd version 11.4, adskflex version 10.8
9:40:51 (adskflex) Server started on allcadserver1 for:
9:40:51 (adskflex) 64800INVPRO_F (consisting of: 59600INVPRO_2009_0F
9:40:51 (adskflex) 55300INVPRO_2008_0F 51400INVPRO_11_0F 49000INVPRO_10_0F)
9:40:51 (adskflex) PLIST 65200REVSYP_F 54100REVITS_9_1F
9:40:51 (adskflex) 54700REVITS_2008_0F 55400CIV3D_2008_0F 55600BLDSYS_2008_0F
9:40:51 (adskflex) 60900REVITS_2009_0F
9:40:51 (lmgrd) adskflex using TCP-port 2080
9:40:51 (adskflex) OUT: "55400CIV3D_2008_0F" samuelE@samuelE-PC
9:40:51 (adskflex) OUT: "55400CIV3D_2008_0F" gboyegao@HP3-AllCAD
9:40:51 (adskflex) OUT: "55400CIV3D_2008_0F" Administrator@BigBoss
9:40:51 (adskflex) OUT: "60900REVITS_2009_0F" Administrator@BigBoss
9:40:51 (adskflex) OUT: "54700REVITS_2008_0F" GboyegaO@HP3-AllCAD
9:41:06 (adskflex) TCP_NODELAY NOT enabled
9:45:06 (adskflex) OUT: "60900REVITS_2009_0F" Administrator@HP1-AllCAD
Do you suggest I ask for a new license file or upgrade the version of my flexnet. My version is 10.8.0, lmgrd 11.4.
Please help out.
