Inventor Forum
Erroe in the went start inventor 2014
6 REPLIES 6
GHASEM_ARIYANI
7053 Views, 6 Replies
hi
Inventor Software startup error the application was unable to start correctly(0x0000142). Appears.
help me
(Win 8.1 64bi and Inventor Professional 2014)
Please use " Accept as Solution", and give kudos as appropriate to further enhance these forums. Thank you!
6 REPLIES 6
DarrenP
in reply to: GHASEM_ARIYANI
you need to install SP 1
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22322619&linkID=9242019&CMP=OTC-RSS...
Windows 8.1 is not officially supported by Autodesk
DarrenP
GHASEM_ARIYANI
in reply to: DarrenP
hi DarrenP
Thank you for your guidance.
The problem was solved.
DarrenP
you also need to do this after installing SP 1
http://usa.autodesk.com/adsk/servlet/ps/dl/item?siteID=123112&id=22446139&linkID=9242018
DarrenP
Does anybody know of a patch for the same problem for Inventor Professional 2012?
Muchas gracias!!! fue la solucion (Y)
What needs to be downloaded?
